Electrical fault
Forum Modellspecifika forum 95/96 V4 Electrical fault
Detta ämne innehåller 4 svar, har 3 deltagare, och uppdaterades senast av 2006-10-08 14:50.
  • #14911
    gmc
    Hi!
    Hopefully someone can help me work through a problem I have on my 1971 Saab 96 V4. Over the past week the indicators have been failing and now they don’t work at all, and there seems to be a problem with the rear tail lights as well.
    I used a line tester on the rear lights (ignition off):
    – If I touch the + on left and right indicator it beeps
    – If I touch + on left indicator and left tail it beeps
    – Same for right
    – If I touch + on left indicator and left brake no beep
    – Same for right
    I am not very good with electrics or the testing equipment but I think there is a major short in the wiring probably at the rear of the car.
    Does anyone have any suggestions as to how I should go about testing the circuts/wiring to track the fault.
    I have tried working with the wiring diagrams for the 1971 Saab V4 but the quality, in Haynes and the Verkstadshandbok CD, are so bad I cannot work out what is what. Does anyone have a good quality wiring diagram.
    If anyone can help it would be appreciated. Please respond in English or Swedish.
    Regards
    Gary McCnnell
    #99009
    Bengt Åkesson
    Just an idea!
    Check the electrical connection socket to the trailer. Perhaps you have a short circuit there.
    [image]http://www.akesson-motorsport.se/tech/dsc00829s.jpg[/image]
    /Bengt
    #99010
    gmc
    Bengt – Thanks
    Have opened the tow connection and checked all wiring, no shorts or misplaced wires, but the same fault appears when testing this as well. Will try dig deeper.
    #99011
    janneh
    When I get strange electrical problems I always check for faulty ground connections. This can give all sorts of ”impossible” trouble. Good luck!
    #99012
    gmc
    I can see why people find electrical faults a nightmare. I have been through the lighting circuts and found nothing that would cause the faults. I disconnected a number of wires to allow testing of the lines and when I plugged everything in again, the front right headlight no longer worked. I changed the bulb around and it still didn’t work. I took the fuse out and put it in again, and now everything works as it should.
    I am not complaining that it is all working, but it would have been nice to find a fault and fix it so that I know the electrics are 100%.
    I will keep an eye on the light and see if the symptoms return in the future. Only thing now, plug in a trailer and make sure the tow bar electrics are still functioning as they were.
    Bengt, JanneH – Thanks for your input.
    Regards – Gary
