emulsion tube and jets Solex 44PII
Forum Modellspecifika forum 95/96 TT emulsion tube and jets Solex 44PII
  • Detta ämne har 1 svar, 1 deltagare, och uppdaterades senast 2012-04-02 18:27 av .
  • #5466
    peterpaul
    Hi,
    I’m rebuilding my Solex 44 PII and I found out that there are some things different then in the workshop manual.
    In my carb there are two different types of emulsion tubes. one with 3 holes and one with 4 holes. Is this normal?
    Are these parts still available somewhere?
    I also saw that the emulsion jets are a different size. Size in the carb is 220. In the XP tuning manual it says 300. What difference does this make? Do I need to change them back to 300?
    Thank you for your anwers.
    kind regards
    Peter-Paul
    #41785
    peterpaul
    Found new emulsion tubes and emulsion jets.
    This topic can be closed.
