Engine part?
Forum Modellspecifika forum 90/99 Engine part?
Detta ämne innehåller 2 svar, har 2 deltagare, och uppdaterades senast av 2006-11-19 22:12.
  • #15127
    gmc
    Hi
    I received a photo of a Saab 99 2.0 litre automatic engine and I was wondering if anyone could help me with a question. I have marked the image with a red arrow which is pointing at what looks like an opening. Should there be something connected to it or is it an inspection hole and the cap is missing.
    Regards – Gary
    #100173
    stefan
    no it is just an hole so you are able to set the timing. If you turn the engine over you will find the degree markings somewhere and they are visible through that hole.
    If my memory does not fail ofcourse………
    #100174
    gmc
    Stefan – Thanks for clearing that up, I just thought it looked like something was missing and thought it best to check up on it.
    Regards – Gary
