Fitting a sports wheel on a V4
Forum Modellspecifika forum 95/96 V4 Fitting a sports wheel on a V4
Detta ämne innehåller 8 svar, har 3 deltagare, och uppdaterades senast av 2007-02-14 23:40.
Visar 9 inlägg - 1 till 9 (av 9 totalt)
  • #15510
    gmc
    Hi!
    I managed to pick up a Luisi sports steering wheel and would like to fit it to my Saab 96 V4 (1971). The center nav that came with it is supposedly for a Saab 900. The following are links to the wheel and the nav.
    Luisi steering wheel
    Luisi wheel nav
    Does anyone know where I can get a nav so the wheel will fit on the 96 or should I post a thread on the wanted forum.
    Any advice would be appreciated.
    Regards – Gary McConnell
    #102663
    andypeak
    Gary,
    try http://www.Dalhems.com or http://www.rallyboutique.com/
    IF the Luisi has the identical bolt pattern as the Sparco steering wheel the order number is RIF 6401 SAAB V4 495.00 SEK.
    #102666
    gmc
    Andreas – Thanks for the links, it seems that the bolt pattern is the same, will contact one of the companies tomorrow just to be sure.
    #102667
    andypeak
    Gary,
    IF i remember correctly there are two bolt patterns 70 and 74mm, I checked my old Dalhems catalogue and the order no for Saab 95/96 from 1970 and onwards are 726401 but you better check with them as you already stated to be 100% sure.
    #102724
    gmc
    Andreas – Checked the bolt pattern and it is 74mm and checked the part, you were right, 726401. Thanks.
    Will look around and see if I can get used one before ordering a new one.
    Regards – Gary
    #103113
    gmc
    Have been around trying to get a second hand one but it doesn’t look like there are any out there. I went in to order one and it seems they are special orders and no one knows if the supplier has stock, will find out tomorrow.
    Is the Saab V4 steering unit unique, the list of ”rattnav” from Luisi is extensive, does anyone know of any other car whose ”rattnav” would fit.
    Regards – Gary
    #103232
    anonymous
    hello !
    i bougth a ”rattnav” from luisi, it fit´s, but i had some problem with mounting the ”rattnav” on to stearingaxel. i needed to hammer it in with a plastic hammer…
    but now i can take the ”rattnav” away if i want to
    #103233
    gmc
    Nikke_76 – Thanks for the info. I have ordered a Luisi hub and hopefully will have it on Wednesday, will keep in mind the tight fit and will report back on how it goes on.
    Thanks – Gary
    #103336
    gmc
    Got the rattnav today and fitted the wheel.
    Luisi Sport Wheel
    No problems with the fit of the nav, a few taps with my hand and it slipped most of the way on, tightening the nut took it all the way in. Looking forward to taking it for a drive to see what it is like.
