Forum › Modellspecifika forum › 90/99 › Gearbox gasket kit for 99 Turbo
- Detta ämne är tomt.
- FörfattareInlägg
- 1 februari, 2020 kl. 22:51 #466990
legio
DeltagareDear friends,
I’m desperately searching a gasket kit for my 99 Turbo gearbox. On the web (https://www.saabits.com/all/saab-900-99-90-gearbox-gasket-kit-manual) I’ve found the kit from the Saab part number 7496003 but it was designed for 5 speed gearboxes and according to Saabits ”the side-cover gasket will not fit and sealant would need to be used instead”.
So this is the reason I’m writing this post: where can I find the right gasket kit or the right side-cover gasket for my 4 speed gearbox?
Thank you in advance
Regards
Alex
- Detta ämne redigerades för 2 månader, 1 vecka sedan av .
3 februari, 2020 kl. 21:52 #467030M.Broberg
Deltagarei THINK this is correct, i had a -80 gearbox that was the same as later 4 speeds.
if that is the case for yours aswell the saab number is 8728677 for the oi-stick housing.
You will have to buy the 5 speed kit or every part 1 by 1. there is no kit that fits the 4 speed .
What you need is really
* Oil stick cover gasket 8728677
*Primary chain cover gasket 8732380
*Diff cover gasket 8728651
*Input shaft seal (in to primary housing) 8710881Then there is
*Seal for gear selector rod (requires dissasembly to fit, doesnt usually leak)
and
*outgoing axles seals. (also usually doesnt fail)4 februari, 2020 kl. 08:38 #467034saabaero
DeltagareThere is 2 different types of the side cover.
My memory is also a little weak here but i think the chillcast housing do not have the same side cover as a later4/5 speed gearboxes.
99 Turbo should have a chillcast gearbox
Maybee the chillcast gasket is aviable from Saabklubben ?It´s an easy task to make your own gasket from a gasket sheet if you don´t find the right gasket
- Det här svaret redigerades för 2 månader, 1 vecka sedan av .
11 april, 2020 kl. 17:29 #468895legio
DeltagareThank you very much guys! Really appreciate
mvh
- FörfattareInlägg
