Gearbox oil level plug
- Detta ämne har 1 svar, 2 deltagare, och uppdaterades senast 2011-07-25 16:48 av .
Forum / Modellspecifika forum / 95/96 V4 / Gearbox oil level plug
I have had some problems with gearbox plugs that really didn’t want to loosen. The size is a bit smaller than 3/8″ and the form is square. The solution is to use the backside of the extender from a 3/8″ socket wrech set that has the right square form. The extender is possible to use on both postive and negative plugs.
