Rear Brake Hose Brackets
Forum Modellspecifika forum 95/96 V4 Rear Brake Hose Brackets
Detta ämne innehåller 0 svar, har 1 deltagare, och uppdaterades senast av 2006-07-19 22:04.
Visar 1 inlägg (av 1 totalt)
  • #14546
    gmc
    I seem to be coming up with a lot of questions and I hope you all don’t mind another. I am still working on the rear brakes of my 1971 Saab V4 96 and the next hurdle to get over is the brackets holding the brake hose to the axlearm. I was about to replace the brake pipe from the bracket to the wheel cylinder when I noticed the bracket was very rusty and I think it will brake off if I try undo the nuts. Does anyone have a solution for fitting new brackets to the axlearm without having to weld them on, I don’t have access to a welding machine. Any work arounds would be a welcomed relief.
    Look forward to meeting those who will be in Stehag Thursday evening – Gary McConnell
