Forum › Modellspecifika forum › OG900 › Replace rotor sparks system
- Detta ämne har 4 svar, 3 deltagare, och uppdaterades senast 2018-09-29 17:35 av .
- FörfattareInlägg
- 27 september, 2018 kl. 22:25 #449700
José Carlos Rodríguez Otero
Deltagare28 september, 2018 kl. 11:19 #449715flaset
DeltagareDetatch distributor cap and replace it, it’s hold on place with 2 metal clips, nothing unusual here.. 😀
// Andreas
9³ Aero SS -03, 9³ Aero Coupé -02, 900T16 Cab -89 & 900T8 -85 på garaget.org || Tech 2
29 september, 2018 kl. 11:33 #449754José Carlos Rodríguez Otero
// AndreasSorrry, but what I really need to replace is the distributor. I enclose a pic. Could you help me.
Regards
29 september, 2018 kl. 17:23 #449764Mags
DeltagareThe rotor (the component depicted in your first post) is ”hidden” under the distributor cap. You need to remove the cap by loosening the two metal clips, just as Andreas described above. With the cap removed you simply pull the old rotor to remove it and then fit your new one. Replace the cap, and you’re done.
29 september, 2018 kl. 17:35 #449765José Carlos Rodríguez Otero
Deltagare - FörfattareInlägg
