Saab 99 towing capacity
Forum Modellspecifika forum 90/99 Saab 99 towing capacity
Detta ämne innehåller 4 svar, har 4 deltagare, och uppdaterades senast av 2006-09-03 18:13.
  • #14773
    gmc
    Hi
    Does any one have a tow bar fitted to a Saab 99 and knows what the towing capacity is. Also, if long distance towing is done with the automatic gearbox, should an oil cooler be added.
    Best Regards
    Gary A McConnell
    #98156
    phermansson
    I just hate unanswered questions, and I have no clue about this
    But the towing capacity shold be noted in the registration papers and on http://www.vv.se.
    Let’s see if a translation can help…
    ”Har någon en dragkrok på sin 99a och vet hur mycket man får dra? Ska man montera ett oljekyl om man ska dra släp långt med en bil med automatlåda?”
    #98157
    Bengt Åkesson
    From the biginning to 1973 1100 kg.
    1974- 1500 kg.
    There was also some reinforced cars that had more capacity.
    Automatic gearbox and cooler – yes.
    /B
    #98158
    gmc
    Patrik: Thanks for the translation.
    Bengt: Thanks for the information.
    Regards Gary
    #98159
    Martin
    To my knowledge, on Automatics with a tow bar an extra oilcooler is reqd as Bengt indicated.
    Many of the automatics have a water-oil cooler. It is to be placed between the expansion reservoir and the radiator. It is also possible to use the air-oilcooler placed under the front bumber (exactly as the Turbo)
