Forum › Modellspecifika forum › Sonett › Clutch/gearbox problem › Sv: Re: Clutch/gearbox problem
17 september, 2014 kl. 07:51 #199019
My specialist placed rings between the clutch plate and the flywheel, which solved the problem (at least partly). Shifting gears is no problem, just now and then it jumps out of first and third gear. Could that be caused by slack in the adjustment of the gear?
