Forum › Modellspecifika forum › Sonett › Clutch/gearbox problem › Sv: Re: Clutch/gearbox problem
17 september, 2014 kl. 20:30 #199043
Do you have normal (full) pedal travel of the clutch pedal?
I had similar problem as you. Pedal travel was only about 50% of normal caused by a too thick clutch disc, as such reducing the effective travel of slave cylinder.
