Forum › Modellspecifika forum › 90/99 › Engine part? › Sv: Re: Engine part?
19 november, 2006 kl. 21:08 #100173
no it is just an hole so you are able to set the timing. If you turn the engine over you will find the degree markings somewhere and they are visible through that hole.
If my memory does not fail ofcourse………
