Sv: Re: Gearbox oil level plug
Forum Modellspecifika forum 95/96 V4 Gearbox oil level plug Sv: Re: Gearbox oil level plug
#30172
gv8
I have had some problems with gearbox plugs that really didn’t want to loosen. The size is a bit smaller than 3/8″ and the form is square. The solution is to use the backside of the extender from a 3/8″ socket wrech set that has the right square form. The extender is possible to use on both postive and negative plugs.
