Sv: Re: Saab 900 Wheel bolts (1992)
Forum Modellspecifika forum OG900 Saab 900 Wheel bolts (1992) Sv: Re: Saab 900 Wheel bolts (1992)
#103060
The distance between the bolt holes are different. After 1987 the Saab 900 has the same bolt measurements as the 9000 model.
If you’re using aluminium rims, try to find bolts for aluminium. Standard bolts tend to get stuck easily.
