Sv: Re: Saab 99 Bosch K-jetronic rally engine.
Forum Övrigt SSR Saab 99 Bosch K-jetronic rally engine. Sv: Re: Saab 99 Bosch K-jetronic rally engine.
#161363
turbo killer
To conclude, the smaller primary pipes have made a difference, but the difference was improved further by using the 90mm trumpets. Here is a final graph with the new exhaust manifold comparing the 40mm and 90mm trumpets.
I think with the ultra big valve head and wilder cam a different manifold may be needed altogether. I have since learned about two manifolds available from Sweden,(thanks to Krister for the link) similar in design to what i already have, but with larger pipes, 42mm primary/48mm secondary and 60mm exit pipe, this one is intended for 2150cc rallycross, the other even larger with 44mm primary/51mm secondary and 64mm exit pipe, intended for 2400cc rallycross.
