Sv: Re: Tool to install the pilot bushing into the cranksh
Forum Övrigt Allmänt Tool to install the pilot bushing into the cranksh Sv: Re: Tool to install the pilot bushing into the cranksh
#134044
stefan
if you get a reduction on the inner diameter you must have a outer diameter that is too large………You do not need any special pressfit on this item, just enough so you are able to gently tap it into place with a suitable tool with support for the bush.
