Sv: Re: Wheel hub/Hjulnav/Hjullager
Forum / Modellspecifika forum / OG900 / Wheel hub/Hjulnav/Hjullager / Sv: Re: Wheel hub/Hjulnav/Hjullager
    februari 10, 2007 at 08:38 #103194
    GMC wrote:
    The cars are on block so that it is easy to get at all the parts, the only problem is you cannot stop the axle from turning so that you can undo the axle nut.
    Thanks in advance – Gary
    If the scrapped car still has working brakes you can put Elisabeth or someone else in the drivers seat and ask her/him to hit the brakes. This will probably stop the turning of the axle. You must press the pedal hard – the power brakes does not work when engine is not running.
    /B
    Bengt Åkesson
    bengt@akesson-motorsport.se
    Facebook
