Abs/antispin and xwd wiring harness
- Detta ämne har 0 svar, 1 deltagare, och uppdaterades senast 2024-07-01 22:35 av .
Forum / Modellspecifika forum / NG9-3 / Abs/antispin and xwd wiring harness
Hi everyone! Apologies for the English, but in desperate need of help regarding my 2009 xwd combi. I am getting no speed reading from my right rear abs/speed sensor on Tech 2. I have replaced the hub assembly and the abs module. Still getting the abs/traction control failure.
Today I checked contenuity on the rear right harness from the connection in the wheel well. I am getting good contenuity from both wires. However when I check for voltage from the module to the connector that holds both the xwd and abs systems, I get zero reading on the voltage on this specific pin. I am assuming I have an open or damaged wire.
I need to know how the wire harness is ran through the car. I can track it back next to the right side (bensyn) gas tank but then the cable seems to go into the frame or above under the rear seats. Is there a way to bypass this or how can I find the issue without tearing the whole underside of the car out?
I have taken it to several so called ”mechanics” and they have either broken more stuff or misdianosed the issue.
Thanks for any help you can provide.
