Demontage bodywork Sonett3
Forum / Modellspecifika forum / Sonett / Demontage bodywork Sonett3
    • mars 18, 2013 kl. 08:25 #7292
      Hello!
      We want to start restoration of our Sonett3 that has a somewhat rusty chassis.
      When we demount the bodywork, should we take out the windshield or can we leave it in when taking of the body?
      Best Regards,
      Erik
        mars 18, 2013 kl. 19:12 #53513
        Guess the chance it will be damaged is bigger when you don’t remove it. If I was in your place I would take it out.
        Alex
        '75 96; very long-term project
        '83 99; after 12 years of use gone to donor heaven
        '94 9000 Aero; after 12 years of use about to be donor
        '02 9-5 Aero; daily family driver
        '96 9000 Aero; pappa's daily driver
          mars 19, 2013 kl. 08:46 #53531
          Okay, thank you. Then we will take out the windshield beforehand.
          Best Regards,
          Erik
            mars 22, 2013 kl. 07:24 #53663
            We also removed it before we removed the body, a good reason to do that is that you probably want to change the window sealing anyway and if you’re repainting the body you’ll have to do it sooner or later.
            Good luck! Feel free to ask further questions!
