The redline, and, installing a tachometer in a 92B
Forum / Modellspecifika forum / 92/93 / The redline, and, installing a tachometer in a 92B
    • februari 23, 2013 kl. 17:06 #7216
      I have a ’56 92B with 28hp. It goes without saying that I need to get every bit of horsepower out of my car to try and keep up with traffic (alas, this is a losing battle!).
      I know my two stroke is a high-revving engine. However, the car has no tachometer and I have no real experience with high revving engines so I am actually afraid to take the car to its full potential since I don’t know the safe limits of the car. I am sure that I consistently shift prematurely out of fear of damaging my car.
      Can anyone tell me what the redline is on a 28hp 92B, and, where I can purchase a tachometer with this redline?
      I think installing such a tachometer would greatly enhance my driving experience while giving me a peace of mind that I am not over-revving my engine.
      Tack!
      Jim
        februari 23, 2013 kl. 17:56 #52690
        -I think there have been modifications done to lower the revs on a 92, some modification on the gearbox.
        -According to the manual the peak in horse power is at 3800 rpm.
        – All after market rev counters I’ve seen have a adjustable ”red line”, the pointer can be set as you wish.
          februari 23, 2013 kl. 18:06 #52691
          You can also buy one with a shift light and set it for the required rpm.
            februari 23, 2013 kl. 20:25 #52693
            Thank you, gentlemen.
            Does anyone know a specific make and model with a shift light that will work on a 2 stroke, 2 cylinder, 6 volt?
            Tack.
            Jim
              februari 23, 2013 kl. 21:37 #52395
              2 stroke, 2 cylinder means 2 pulses per engine revolution – which is just like any 4-cyl 4-stroke. On the other hand, the fact that it has kind of a funky ignition system with two coils etc; and 6V electrics; would lead me to look in the motorcycle world for a suitable tach. Get one for a 1-cyl 2-stroke 6V motorcycle, and hook it up to either one of your coils.
                februari 23, 2013 kl. 22:55 #52695
                Ha! Like looking for a needle in a haystack. So far, no good. But, I’ll keep looking……
                  februari 24, 2013 kl. 11:22 #52704
                  What about a tach for marine purposes? Isn’t two-stroke technology still used widely in boat engines? Snowmobiles? Jet-Ski?
                    februari 24, 2013 kl. 18:25 #52719
                    I’ll use marine, motorcycle, whatever will work.
                    Are there any 92 new-groupers here that use a tach?
                    Tack.
                    JIm
                        februari 25, 2013 kl. 15:41 #50592
                        Thank you, all.
                        Well I guess these digital gauges will work, but, really I don’t think they would be appropriate or functional. It would be great if there was an analog version, with a needle, and a shift light, but I guess I am dreaming.
                        Jim
                          februari 25, 2013 kl. 18:02 #52749
                          Model: 2CT52-6V on http://www.westach.com/products/SINGLE/2%20INCH/TACHOMETERS/index.php maybe? Not exactly cheap but should work.
                            februari 25, 2013 kl. 19:48 #52758
                            Hej Patrik,
                            An excellent lead, thank you.
                            I found another source as well, even MORE expensive; they modify & modern vintage tachs. They are here:
                            http://williamsons.com/index.html
                            I am currently talking to them about preparing a vintage Sun tach that will work on my 92B. If we come to an agreement expect to see a photos here. 🙂
                            Thanks to all!
                            Jim
                              juni 8, 2013 kl. 14:09 #56440
                              It took awhile but the tach is finally installed. If you are an insomniac & need something to help you sleep, here’s a video of the tach in action:
