Tool to install the pilot bushing into the cranksh
- Detta ämne har 1 svar, 2 deltagare, och uppdaterades senast 2009-01-20 08:55 av .
Hello people,
how made is the tool to install the pilot bushing into the crankshaft, to
avoid doing the reduction of the internal diameter of the bushing?
The internal diameter reduced of about 0,25 mm after that I mounting it.(now
the internal diameter is 14.75 mm)
The bushing is longer 20 mm and after the mounting to the end of the blank
hole of the crankshaft, after the bushing, there are 9 mm so is difficult
to adjust the correct diameter with a cylindrical borer.
Somebody can attached dome photos of this tool?
Many thanks
