Utvändiga dörrlister Saab 95-78
Forum / Modellspecifika forum / 95/96 V4 / Utvändiga dörrlister Saab 95-78
- Detta ämne har 3 svar, 2 deltagare, och uppdaterades senast 2017-05-23 23:17 av
Andy Deans.
maj 9, 2017 kl. 13:33 #429948
Hej! Ska efter lackering nu sätta tillbaka de utvändiga krom/gummilisterna på dörr och sidoplåt innan bakre hjulhus, på min 95:a -78. Problemet är bara att gummit är kortare än kromlisten. Har sett detta på flera andra V4:or (var ju så på min också innan lackering) Är det något man får leva med eller finns det något sätt att fixa detta ? Skulle ju vara såå snyggt om list och gummi var lika långa! Tacksam för tips och råd!
maj 9, 2017 kl. 18:51 #429971Sorry, I have to write in English, Swedish is not one of my languages.
I have the same problem on my 1978 SAAB 96!
I have been told that if you wash the rubbers in warm water water, and then rub glycerine into them, they become like new.
I will be trying this in the next few days, and will report back.
I was also told to fit them using double sided tape, this stops them shrinking back, because they are stuck to the door.Regards
Andy Deans
Det här svaret redigerades för 9 år, 5 månader sedan av
Andy Deans.
maj 9, 2017 kl. 19:02 #429973Hi Andy! Thanks for your input. Sounds like a smart thing to do, that with the double sided tape. Looking forward to hear more about the cleaning of the rubbers! Regards Klas Carlborg
maj 23, 2017 kl. 23:17 #430636Klas
Well I can say that washing them in warm soapy water, and rubbing glycerine into them certainly makes the rubber come up like new.However sticking them on with double sided tape, did not work. They started coming off the door within 48 hours.
Perhaps I should have used better quality double sided tape….I have a spare rubber, so I have cut off a small piece, and have now added it in to make up the short length, , and used bathroom sealant to stick the rubber/trim assembly to the door. This seems to be working.
Regards
Andy
