Valve-play 99 B-engine 8V
Forum / Övrigt / SSR / Valve-play 99 B-engine 8V
    • augusti 7, 2009 kl. 15:06 #20570
      Hello!
      Which value should be the valve-play on a tuned rallye-engine B-engine 99 with carburettors and rallye-cross camaxle?
      I think something like 0,5 mm?
      Tack!
      Erik
        augusti 7, 2009 kl. 18:50 #143730
        Hallo
        The camshaft grinder will know.
        But saab often used 0,2 mm inlet and 0,4 mm exhaust.
        Many camshaft have 0,3 mm inlet and exhaust.
        Niklas
          augusti 8, 2009 kl. 09:30 #143743
          Hm, I don’t know who is the camshaft-grinder. Bought the engine as it is. :confused:
          It is a rallye-cross engine with bigger valves, ”hotter” camshaft, 2x Weber 45 DCOE. 176 hk.
          Erik
