Overheating when idling
Forum / Modellspecifika forum / Sonett / Overheating when idling
    • september 17, 2014 kl. 08:19 #26556
      When idling the engine temperature quickly goes to the red. I already installed an auxiliary electric fan, but that is hardly sufficient. Anyone recognizes this problem and has a solution? Bigger radiator?
        september 18, 2014 kl. 05:20 #199048
        I have never had any problems with standard radiator.
        Maybe the water pump is not working propably?
        Sabbe
          september 18, 2014 kl. 15:59 #177215
          I had a similar reaction on my Sonett some years ago, I solved it by changing the radiator cap, the water was not circulating properly. Sometimes you gotta be lucky 🙂
          Best Regards and good luck
            september 18, 2014 kl. 18:24 #199058
            Thank you for your tips, I’ll have a go at it.
              september 19, 2014 kl. 15:22 #176717
              How old is the radiator? If it still has the original cooling block it is time for a recore. I had the rad of mine redone with the core used in a 99 Turbo as preventive maintenance 14 years ago; still works like a charm.
              Alex
              '75 96; very long-term project
              '83 99; after 12 years of use gone to donor heaven
              '94 9000 Aero; after 12 years of use about to be donor
              '02 9-5 Aero; daily family driver
              '96 9000 Aero; pappa's daily driver
                september 19, 2014 kl. 17:59 #172283
                At least 20 years (has been stored 20 years). This was one of the solutions I was thinking of, maybe even a bigger core. Where was it done (Norway or Holland)?
                  september 19, 2014 kl. 18:40 #172281
                  In Holland. Where is the sensor to the electric fan located?
                  Alex
                    september 19, 2014 kl. 18:54 #172272
                    No sensor, manually operated :).
                    (waar heb je jouw radiator laten opknappen?)
                      september 19, 2014 kl. 20:16 #172124
                      Bijl in Haarlem http://www.detelefoongids.nl/bijl-radiateuren-vof/18945051/5-1/?what=Bijl+radiatorenservice&where=Haarlem.
                      Alex
                        september 19, 2014 kl. 20:47 #171962
                        Dank je, dat is lekker dichtbij.
                          oktober 5, 2014 kl. 19:00 #155846
                          I ordered and installed a new radiator cap. Now waiting for the results 😉
