Weight difference metal/fiberglass
- Detta ämne har 3 svar, 3 deltagare, och uppdaterades senast 2008-02-11 23:57 av .
I am looking into whether or not it is worth replacing body parts on the V4 from metal to fiberglass to save weight. Does anyone know the weights of:
Metal hood/Fiber hood
Metal boot/Fiber boot
Metal front fender/Fiber front fender
Metal rear fender/Fiber rear fender
I dont know how much the weight is on the specific parts but you will save approximately 40 kg if you change all the parts.
Atleast at RP-Glasfiber you can choose how thick the material should be, i got an old pair of frontfenders that are about 5mm thick but the weight is still less than a metalfender i also got a new pair of extra thin rear fenders from RP and the weight on them is very close to nothing. 😀
Regarding the trunk i saved the ”frame” from the old one to be able to use the original lock so the weightloss on this is only about 5kg but can be made better (lighter) with another solution, hoodpins for example.
