emmett jenner
oktober 27, 2013 kl. 22:35 #60552
Before the turbo upgrade. Before fitting t5.5 – this was with the standard TE05 and some of my tuning. :ID
oktober 27, 2013 kl. 21:08 #57091Back from the bodyshop. Wasn’t expecting to have to refit the majority of the aero kit… 😕 so tomorrow appears to be all mapped out for me. On the plus side… although it’s difficult to see in the photograph the paint is now perfect, every panel is dent and scratch free and all the same colour… I doubt it’s been in this sort of condition for a long time. It’s always been a pleasantly rust free car but the overall condition of the bodywork looked like it was 24 years old. It cleaned up nice enough as it was but I’ve been wanting to get it properly painted for a long time.
Booked in to have the roof changed and the seats refreshed early November. In the meantime I’ll be swapping the engine and converting it to T5. Watch this space.
Cleaned the oil and dirt from the engine bay. Oil leaks, 25 years and 160,000 miles worth of use. Lots of dirt, lots of oil.
Very pleased to find no rust. A bit of surface blemishing but no bubbles, no corrosion, no flaking… it’s really quite impressive. For example… look at the front cross member… it can be a bit of a hot-spot for rust… some of the cleanest cars externally can have big flakey chunks of hidden rust along the front cross member. It’s under the radiator and exposed to weather as the front facing part of the car. The driveshaft tunnels are totally solid, no sign of any corrosion. To make it perfect you’d have to strip it out, i.e. remove all the hardware, bit of sanding to prepare it and then it could be painted as it is!
Few more bits done, more parts arrived.
Reconditioned steering rack installed and I’ve resealed the supply hoses.
New Bilstein shocks.
Flywheel with the CNC pattern for the crank sensor
A lovely cam cover
Also have to renew front and rear brake pads as both have worn quite thin. Anyway, better get on with it. Lots to do!
Here comes the motor 😀
I have a few more pieces to bolt on and the crank sensor hole to drill.
Turns out some daft bugger who built the gearbox (long before I was getting involved in these things) messed up the job. I had the engine back in the car, installed the driveshafts, oil cooler lines, speedo cable, engine mounts and exhaust. Came to connect the gear linkage and line it up but the bloody thing does not select anything other than 1st or 2nd.
So now the engine is back out of the car and I’m going to have to take off the primary drive housing and reset the spring on the gear selector rod. 👿
At least I haddn’t got too far with the engine installation. I reckon this is going to set me back a good 4 or 5 hours!
Here we go… This is the pin in the primary drive housing. That pin centralises the shifter shaft so when you move the shifter left or right it will spring back to centre.
The selector shaft was positioned at spot 1. So it would be impossible for the shaft to rotate. 🙄
When I put it back I will have to turn the shaft slightly and put the pin between the two ends of the spring in position 2.
All back together now. Flanges cleaned up and resealed. Works now. So annoyed. That was a whole day wasted. 😥
Tomorrow I’ll put it back into the car and just see how far I can get.
Yes, I like a little bit of good quality improvement where possible. Difficult to improve on an already pretty good design though.
Still a bit annoyed by yesterdays setback. I wanted to be much further forward by now. I was hoping to have the engine started by Sunday afternoon but not quite got there. 🙁
So still left to do:
– hook up intake hoses
– coolant hoses
– bumper, lights and grill
– reconnect wires for engine equipment
– complete T5 wiring
– reprogram the T5 ECUI suspect the car would start and run ok with the existing ECU program but I doubt whether it will be agressive enough as the donor car was LPT. I also want to turn off the lambda.
You can see some things in the picture above showing some of the little changes I make when putting in the T5.
1. The trionic ECU is mounted where the original APC would be mounted. You have to remove the ECU board from the shell and flip it round so the ECU plug points away from the wheel arch and the wiring can come forward to follow the standard wiring route around the inner-wing.
2. Can’t quite see it but replace the AMM with a piece of stainless tube. It must be a standard diameter like 3-inch as I always seem to have a bit of tube hanging around.
3. Make a little gap between the coolant bottle and the intake snorkle by cutting a few inches off the bottom of the snorkel so it can be moved closer to the front of the car. Then you can clip the MAP sensor onto the inner wing between bottle and the snorkle as in the picture.
I’ve left the original circular locking body interface connector from the 9000 on the ECU wiring loom. Worked out that you can eaisly remove the unnecessary pins from the body side of the connector so that is perfect for properly terminating unused wires. The unused wires stay in the engine side of the loom but don’t mate up to anything in the body side of the connector.
This is the minimum number of wires I think are required for the T5 conversion with this particular set of loom and sensors.
I traced it all back and I’ll wire these two connectors into the car. Once that is done the Saab 9000 T5.5 loom will be plug’n’play
A bonus of keeping the existing T5 wiring loom and not making any changes is that it’s originally positioned under the inlet manifold. As I’m trying to replicate the T5 setup as close as possible I have the idle control valve mounted under the throttle, same as the 9000. I also have the wires for the injectors coming in under the inlet manifold the same way.
Also, something else new are the clips on top of the connectors to the injectors. I was reading the other day that the T5 injectors have holes in the bottom of them which direct a jet of fuel precisely in the correct direction. The plastic braces between the connectors are meant to fix the spray pattern for the injectors in the correct orientation! So they aren’t just for making it look pretty, they keep the injectors mounted straight so the fuel sprays correctly into the engine.
I’ve adjusted the ECU image so the lambda is turned off. I used the tuning wizard in T5 suite to bump up the boost, fuel and ignition details.
Started installing the keyless entry as I have to do that before I can finish the wiring. I’ll be opening the wiring insulation down the inner wing on the left side between the fuse box and the front of the car. It is better to get the alarm wiring tucked into there at the same time as the ECU wiring rather than doing them separately.
Here’s an engine bay pic.
