Temperature sensor Saab 900
- Detta ämne har 2 svar, 2 deltagare, och uppdaterades senast 2018-12-01 21:04 av .
Forum / Modellspecifika forum / OG900 / Temperature sensor Saab 900
The engine temperature gauge is not working. I would like to know where is the sensor. I only locate the thermostat, but I asume that thermostat and temperature sensor are differents.
The sensor is usually in the same housing as the thermostate. It is a small sensor with one cable with a cable lug attached to.
